When running Mango on linux it is generally desirable to expose Mango on port 80 and 443 which require privileged access. This document describes how to configure linux to run Mango on these ports safely.
Step 1 Create a user named ‘mango’ and unzip the core into the desired location as the mango user.
Step 2 configure mango to run on ports 8080 and 8443
Step 3 setup ip tables to route messages from 80 <->8080 and 443 <-> 8443
Setup ip tables by executing the following commands
sudo iptables -t nat -A PREROUTING -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080sudo iptables -t nat -A PREROUTING -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443sudo iptables -t nat -A OUTPUT -d 127.0.0.1/32 -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080sudo iptables -t nat -A OUTPUT -d 127.0.0.1/32 -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443#persist the results across reboots (Doesn't work on Amazon linux 2)
#Amazon Linux 2: sudo yum install iptables-services
sudo service iptables saveSetup ip v6 tables
sudo ip6tables -t nat -A PREROUTING -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080sudo ip6tables -t nat -A PREROUTING -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443sudo ip6tables -t nat -A OUTPUT -d ::1 -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080sudo ip6tables -t nat -A OUTPUT -d ::1 -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443sudo service ip6tables save
