Updating Mango Store Path
As you may have noticed, Mango Automation has recently undergone some rebranding. As part of this process the url to the store has changed. Please following the instructions provided to update your mango store variable to the new path.
Instructions
If you have not already, create a new directory in the root mango folder called overrides/properties and copy env.properties into the properties directory.
Navigate to the env.properties file located in the overrides folder and find the store.url variable.
Replace “https://store.infiniteautomation.com” with “https://store.mango-os.com”.
Save the changes you made to the env.properties file.
