Overview
The format of the Point Values endpoints has changed in v2, this guide has been created to help developers migrate to the new format.
Content types
Both "text/csv" and "application/json" content types are supported.
URL Parameters
Dates
Dates are IOS formatted strings using the pattern yyyy-MM-dd'T'HH:mm:ss.SSSZ. If no date is supplied for the parameter a time and date of the request's submission will be used.
Example 1: 1994-11-05T08:15:30-05:00 corresponds to November 5, 1994, 8:15:30 am, US Eastern Standard Time.
Example 2: 1994-11-05T13:15:30Z corresponds to the same instant.
More on the pattern here: https://www.w3.org/TR/NOTE-datetime
Timezones
Timezones can be set in 2 ways, by supplying a timezone parameter or by applying an offset to the Date parameter(s). Timezones can be supplied in 3 formats:
- Offset such as +/-00:00 to 23:59 or Z
- Zone Offset such as GMT+2, GMT-2, etc
- Region ID such as
US/Hawaiisee here for more info
The timezone for the request is set using the following precedence.
timezoneparameterbeforeorfromparameter if suppliedtoparameter if supplied- If no dates are supplied the server timezone is used
Date Format
The dateFormat parameter allows returning dates formatted as strings. By default times are returned as millisecond instants. As above one example is the ISO format yyyy-MM-dd'T'HH:mm:ss.SSSZ. But any format can be used that is supported by the Java DateTimeFormatter.
More on the format here: https://docs.oracle.com/javase/8/docs/api/java/time/format/DateTimeFormatter.html
Cache
Point values are cached in Mango's memory for a variety of reasons and the size of the cache can be controlled in the data point's settings. Cached values are not necessarily saved to disk but can be duplicated in both places. To access cached values the useCache parameter is supported on all non-rollup endpoints. When using the cache to return values note that saved (non-cache) values override values at the same timestamp.
| Mode | Description |
| NONE | No cache used |
| BOTH | Cache and historical interleaved |
| CACHE_ONLY | Only cached values |
Bookends
Bookends are only available on time range requests, they are useful when charting data. When bookend=true the value at the from query time and to query times are returned. The first bookend is either the value exactly at from or the value before it. The ending bookend is the last value within the time range. The resulting data will be supplied as the bookend boolean field in the data. If not used or the value is not a bookend, the field is not returned.
Limits
When using limits the results vary based on the endpoint. As a general rule single array responses are limited based on the size of the single array. Multiple array results are limited on each array. So requesting a single array of latest values for many data points with a limit of 10 will return a single array of up to 10 values and these may not necessarily contain values for every point. When requesting the same latest 10 values for the same points as multiple arrays you will get an array of up to 10 values for every point in the request.
Simplify
Simplify is only available on Numeric data points and reduces the number of values returned without losing the peaks and valleys of the data. It uses an enhanced implementation of the Ramer–Douglas–Peucker algorithm. Simplify control works by using 2 parameters on non-rollup endpoints. Simplify can be used to process the data once with a known tolerance level or to auto detect the tolerance based on a desired number of values to be returned. By not providing either of the parameters Simplify will not be done on the values. Auto detection will take a little longer but using a tolerance requries knowing the data better.
| Parameter | Description | Default Value |
| simplifyTolerance | Tolerance for use in Simplify algorithm | null |
| simplifyTarget | Target number of values to return per data point, auto tolerance | null |
Rendering
Point values can be rendered using the data point's renderer settings by setting useRendered=true. The resulting data will be supplied as the rendered String field in the data. If not used the field is not returned.
Rollups
Rollups work with a time period and a time period type. For example you can rollup the data into 30 Day average values. The rollups available for a data point depend on the data type.
Rollup Axioms
- A starting time is inclusive, an ending time is exclusive
- Every period starts with the value that existed prior to the period as though timestamped at the start of the period and not before, unless there is a value at the exact start time of the period.
- Periods with no value prior to the start time have a NULL startValue
- No value prior or within the period all statistics are NaN except count and sum which are 0 and First (value and time) and Last (value and time) which are NULL
- No statistic will ever require a value in the next time period
- The last value added to the statistics (currently the done method) is the last value within the period.
- The end value is the last value unless it doesn’t exist, in which case it’s the start value
- Previous value is the latest value prior to the period
Date Truncation
Rollup queries can have thier from and to times truncated to round date/time values using the trucate=true parameter. When truncating a date/time all smaller period types are set to 0. Truncation by the various period types is as follows.
| Period | Description |
| Years | date - (periods % year of century) |
| Months | date - (periods % month of year) |
| Weeks | date - (periods % aligned week of year) Where the aligned week of year represents concept of the count of weeks within the period of a year where the weeks are aligned to the start of the year. For example, in a calendar systems with a seven day week, the first aligned-week-of-year starts on day-of-year 1, the second aligned-week starts on day-of-year 8, and so on. Thus, day-of-year values 1 to 7 are in aligned-week 1, while day-of-year values 8 to 14 are in aligned-week 2, and so on. |
| Days | date - (day of year % periods) |
| Hours | date - (hour of day % periods) |
| Minutes | date - (minute of hour % periods) |
| Seconds | date - (second of minute % periods) |
| Milliseconds | date - (millisecond of second % periods) |
Numeric Rollups
| Rollup | Description |
| NONE | No rollup, return raw values |
| ACCUMULATOR | The last value minus the previous value |
| AVERAGE | The start value and all values in the period weighted by time |
| COUNT | The number of sampled or logged values within the period |
| DELTA | The change in point value within the period. 0 values and no start value: NaN, 0 values w/ start value: 0, 1 value with start value could be anything, 1 value with no start value is 0 |
| FIRST | The first logged value within the period |
| INTEGRAL | The integral of the values during the period, taking into consideration the start value. The weighted sum of values by their durations |
| LAST | The last logged value within the period |
| MINIMUM | The largest value of any values within the period, taking into consideration the start value |
| MAXIMUM | The smallest value of any values within the period, taking into consideration the start value |
| START | The value before or exactly at the start of the period |
| SUM | The total of all values within the period, doesn’t count the start value unless the start value occurred exactly at period start |
Non Numeric Rollups
Latest Values Endpoints
Latest values for a single point
GET rest/v2/point-values/latest/{xid}
Returns point values in time descending order starting at the first value before the 'before' time.
GET Url Parameters
| useRendered | return value as 'rendered' member | false |
| dateTimeFormat | returned timestamp format | null |
| before | return values before this time | now |
| timezone | java timezone name | timezone to use |
| limit | limit the results | no limit |
| useCache | interleave cached values into results | NONE |
| simplifyTolerance | tolerance for use in Simplify algorithm | null |
| simplifyTarget | target number of values to return | null |
JSON Response Format
"timestamp" : 915184800000,
"value" : 1.0600244013244962,
"annotation" : "John set this value",
"rendered" : "1.06 V",
"cached": true
}]CSV Response Format
timestamp,value,cached,rendered,annotation
915184800000,1.0600244013244962,true,"1.06 V","John set this value"Latest values for multiple points as a single array
GET rest/v2/point-values/single-array/latest/{xids}
POST rest/v2/point-values/single-array/latest
Returns point values in time descending order starting at the first value before the 'before' time. The returned values are in a single array with the value field being the xid of the point the value belongs to.
GET Url Parameters
POST Body
"xids": ["point1","point2"],
"useRendered": true,
"dateTimeFormat": null,
"timezone": "US/Hawaii",
"before": null,
"limit": 5000,
"useCache": "BOTH",
"simplifyTolerance": 0,
"simplifyTarget": 1000,
}JSON Response Format
"point1": {
"cached": true,
"value": 1.0,
"rendered": "1.0V",
"annotation": "Point1 annotation"
"point2": {
"cached": true,
"value": 2.0,
"rendered": "2.0V",
"annotation": "Point2 annotation"
timestamp,point1,point1.cached,point1.rendered,point1.annotation,point2,point2.cached,point2.rendered,point2.annotation
915184800000,1.0,true,"1.0V","Point1 annotation",2.0,true,"2.0V","Point2 annotation"Latest values for multiple points as a multiple arrays
GET rest/v2/point-values/multiple-arrays/latest/{xids}
POST rest/v2/point-values/multiple-arrays/latest/
Returns point values in time descending order starting at the first value before the 'before' time. The returned values for each point are in separate arrays.
GET Url Parameters
POST Body
"xids": ["point1", "point2"],
"dateTimeFormat": "yyyy-MM-dd'T'HH:mm:ss.SSSxxx",
"before": null,
"limit": 5,
"useCache": "BOTH"
"point1": [{
"timestamp" : "2017-12-01T05:57:21.969-10:00",
"cached": true,
"value": 1.0,
"rendered": "1.0V",
"point2": [{
"cached": true,
"value": 2.0,
"rendered": "2.0V",
}CSV Response Format
timestamp,xid,value,cached,rendered,annotation
"2017-12-01T05:57:21.969-10:00","point1",1.0,true,"1.0V","Point1 annotation"
"2017-12-01T05:57:21.969-10:00","point2",2.0,true,"2.0V","Point2 annotation"Time Range Endpoints
Time range queries for values returned in time order. All queries return values in the range from <= timestamps < to.
Time range for single point
GET rest/v2/point-values/time-range/{xid}
GET Url Parameters
| from | return values at and after this time | now |
| to | return values before this time | now |
| bookend | always return values at the to and from times |
false |
"cached": true,
"bookend": true
timestamp,value,bookend,cached,rendered,annotation
915184800000,1.0600244013244962,true,true,"1.06 V","John set this value"Time range for multiple points as single array
TBD
Time range for multiple points as multiple arrays
TBD
Rollup Endpoints
Rollup endpoints are time range requests that rollup the data.
