Setting up Remote Backups
iDrive is a excellent remote backup service you can use to set up automatic remote backups of your Mango data and configuration. iDrive automatically tracks 10 versions of each file so besides a disaster recovery it can be a great way to roll back your configuration or database if needed.
Your MangoES contains all the software to interface with iDrive just follow these instructions to configure it:
Get an iDrive business account at www.idrive.com
Connect to the MangoES over SSH
Use the following commands to configure
cd /opt/Idrive_ARM
sudo nano CONFIGURATION_FILEedit the following lines:
USERNAME =
PASSWORD =
EMAILADDRESS =
#Set a top level folder name in the Idrive cloud to back up files into
BACKUPLOCATION = ctr x to save and quitsudo ./login.plwait for success message. Note that if you logout, you’ll need to supply the password in the CONFIGURATION_FILE again.
sudo ./Scheduler_Script.plFollow the prompts in the script.
You are done.
You can run: sudo ./Backup_Script.pl to start the backup now .
