Changing Network Configurations
On the System Setting page under Network Configuration you can modify the network options.
USB Config Utilities
The included USB Drive makes field configuration really easy without ever needing to log into the server. You can use the configuration files on the USB drive to easily set IP address and other configurations without ever logging into the device.
To use the USB tool:
- Plug USB into a computer
- See ReadMe.pdf for detailed instructions
- Edit the property files as needed
- Plug the USB drive into the MangoES
- Three light will flash indicating the configuration has been successful.
